Reload this Page >
Chipmunk Brotherhood.
Old 04-18-2024, 02:29 PM
  #201
gow589
Originally Posted by RICKSTUBBZ
Sure is looking nice!
I bet there are not very many people with an engine test stand like that one.
Being on wheels, I just need to add some big servos to steer it!
Old 04-19-2024, 12:57 PM
  #202
gow589
Break in went well; Stinger 125cc:
Old 04-19-2024, 01:14 PM
  #203
RICKSTUBBZ
RICKSTUBBZ's Avatar
How big is that baseball bat you have bolted to the front of that thing...
Put some elevons and maybe a vertical stabilizer between the bottom shelf and the top shelf and you might be able to fly that table...
maybe take the vise off for balancing purposes?
The way you are going, the Chipmunk will be in the air soon
Old 04-19-2024, 01:32 PM
  #204
gow589
Prop is 29". I was thinking of putting servos on the wheels, jumping on the table and driving it around like a flying carpet. . .flying door-table I guess.
Old 04-26-2024, 07:55 AM
  #205
gow589
Still making progress. Getting all the wheel pants, fairings
, cowls and such ready to paint.
Old 04-28-2024, 11:24 AM
  #206
gow589
Trying to get everything except the radios/batteries so I can see what I need to do for CG. Going to build a real simple CG jig. Graphics are a little off in size but that's ok. I don't plan to be entering any scale contest. The 3d printed strut covers worked well and I 3d printed mounts for the wheel pants.
RICKSTUBBZ (04-28-2024)
Old 04-28-2024, 11:48 AM
  #207
RICKSTUBBZ
RICKSTUBBZ's Avatar
You are moving right along !
Won't be long and that thing will be in the air?
From what i am seeing, you must have printed the pilot as well, or at least parts of him?
Old 04-28-2024, 12:00 PM
  #208
gow589
Yea I downloaded him online. I adjusted him for size and he was huge. I had to do it a second time. I printed his arms same scale and they did not look right so I printed the arms slightly smaller.
Old 04-29-2024, 03:01 PM
  #209
gow589
I made a very simple jig for locating the CG. This will help with placement of everything. I used a round aluminum rod rubber banded to the spars. The center of the rod is located on the desired CG. A simple stand I can move forward or back until it balances. Simple.
Old 04-30-2024, 03:03 AM
  #210
Tony Hallo
I always found it difficult balancing low wing planes up right and was wondering how you got it to balance. I understand now after looking over the second photo.
gow589 (04-30-2024)
Old 04-30-2024, 05:32 AM
  #211
RICKSTUBBZ
RICKSTUBBZ's Avatar
do you have a bridgeport and a lathe hanging out in that shop somewhere?
making stuff like that jig is half the fun for me....
i was confused at first until, like Tony, I saw the last photo, realizing you have the wings pulled out....
Old 04-30-2024, 06:54 AM
  #212
gow589
I have a lathe but that was just tubing cut and welded with grinder. I am pretty good with basic metals. I restored the NASCAR in the background which included cutting off the old steel body and fabricating a new steel body among other things. The NASCAR is going to be auctioned of at Mecum Indy mid May.
I may get my wife's scale so I can can see what it weighs. It will allow me to calculating balance of the rest of the components.
Old 04-30-2024, 10:55 AM
  #213
gow589
Ran some initial numbers on the CG. I am paying for putting 2 servos in the tail as I expected. Fuel and smoke tank will go on CG. I will have to work hard to keep everything as forward as I can. Laying it out as I have done in the spreadsheet brings me to needing 21oz in the nose. I think I can get some stuff further forward than listed but this gives me a good outline of what I am up against.
Old Yesterday, 04:51 AM
  #214
Tony Hallo
So you weight is coming in at 34 pounds? I believe I read some in low 40's.
Old Yesterday, 05:51 AM
  #215
gow589
That's what it looks like.
Old Yesterday, 08:18 AM
  #216
gow589
Just noticed, the column that says "CG" should say "moment". The arm is the CG.
Old Yesterday, 12:01 PM
  #217
gow589
This is labeled more correctly:
