Welcome to Club SAITO !
RE: Welcome to Club SAITO !
Thanks! I haven't had a lot of flights on it yet this season, but it flies great.
Here is a link to the YouTube video posted by KVMA club photographer, Joe Gilbert.
http://www.youtube.com/watch?v=TK6Bj...2&feature=plcp
Unfortunatley there is a helicopter flying behind the videographer so you can't hear the Saito in most of the video.
Jaybird
Jaybird
Here it is... it's usually included with the Golden Knight. Will also fit the .56 but not sure of the engines in between those sizes.
http://www.horizonhobby.com/webapp/w...pe=productgrid
The part no. is SAI50GK93
Just my $.02
Bob
Just my $.02
Bob
Jaybird, that's one beautiful example of one of my all time favorites. Makes me regret selling mine, (built from a Pica kit).
ORIGINAL: Jaybird
I've just installed a 125 in a Great Planes WACO YMF-5D. Superb combination.
Still breaking mine in on YS 20/20 fuel. It leaves quite a smoke trail and a lot of slime on the bottom after a flight. I've been slowly leaning the low speed needle to get a more reliable idle.
Jaybird
ORIGINAL: svenska3
I have this beautiful 125 I need to find a plane for. I'm a intermediate pilot. I don't fly 3-D. Any suggestions???
Walt
Walt
Jaybird
My Feedback: (102)
Bob, it fits everything from the .50 through the 1.25. It s ID is slighlty smaller than the 1.25s carb venturi diameter but most claim it does not effect the 1.25s power.
ORIGINAL: blw
Here is an update to the Saito Club:
Riadh #781
CH Ignitions #782
Rowdyjoe #783
Anyone else have a Saito and need a number?
ORIGINAL: []TEX[]
I run strictly SS bearings and change them every year. You are wasting your money paying for anything else. They must be seated properly as well, my guess is that the rear bearing was not seated completely causing catastrophic failure.
I use only helicopter fuel in my saito which has 30% nitro and 23% oil content. Saito suggests this as well and to be fair, I fly helicopters so I already have access to the fuel and have several cases of it.
''A fuel with 10 to 15% nitro is fine, however higher nitro content (up to 30%) is suggested''
ALL my bearings come from RC-Bearings and not one has ever failed on any of my motors. I don't use after run oil or magic potions. My motors sit in the model in my garage all winter and start right up at the beginning of the season with zero rust.
RC-Bearings is the only place you should be buying bearings, period.
ORIGINAL: AeroFinn
This is interesting. So what do I sacrifice if I go with stainless steel set instead of the hard chrome set? Nothing except for a little price difference? How's the max performance? Anayways, I think the worst alternative is to use bearings that may fail in the way that happened to my engine: the ring that holds the balls in their place failed totally = metal particles all over the inside of the engine. So is it now such that the stainless steel bearings just wear out, like good quality hard chrome bearings? Further, I think changing bearings in every winter as a regular maintenance is something I can live with. I would not like, however, to dismantle an engine during the flying season for changing bearings. I think I run somewhat 6-10 gallons of fuel (15% nitro) in every season. So what do you think might suit best in my case: hard chrome or stainless steel bearings? Thanks artto
ORIGINAL: RC-Bearings
There is no basis for this comment. Hard Chrome is a plating process that is not used on bearings. It is used to hard face wear areas such as cam lobes, etc. Stainless steel used in bearings is hardened to the same range as the chrome steel used in bearings. I sell many times more stainless sets than chrome steel because of the rust issue. No one has yet complained about shorter service life.
ORIGINAL: Hobbsy
Stainless would not last nearly as long as the HardChrome bearings plus Boca is a sponsor of this site. And I honor that.
Thank you Tex. I guess I will go with the stainless steel set then.
ORIGINAL: blw
Riadh #781
CH Ignitions #782
Rowdyjoe #783
I guees that makes me #784?
ORIGINAL: AeroFinn
regarding the FA-125a: has anyone tried to install a FG-21 cylinder & piston on it? I'm not sure about the exact details of the two engines but if this would work a small power increase might be gained due to the increase in displacement. This is provided, of course, the stock FA-125a carb and glow fuel could be used. And the engine could be converted (if so desired) to gas, too. So what do you think, should it work perfect or is it just gambling? I need to replace the cylinder and piston for my FA-125 anyways so that's why I'm interested in this option. Rgds artto
The bore is only .3mm (.012") larger & the FG engine is most likely lower compression for use W/the lower octane of gasoline so there would probably be little if any power boost.
ORIGINAL: SrTelemaster150
ok I guess you are right..I actually called Horizon Hobby for this matter. I was told that even though the FG-21 design is based on FA-125a they are totally different engines. According to the Horizon Hobby' s rep even the crankcase and crankshaft are different, too. He explained the cooling arrangement of the two engines is so much different, hence the reason for the parts not being interchangeable. I dunno..I think I'm not qualified enough to do the testing to confirm all this. So I will go for the regular FA-125a parts and forget about playing with the FG-21 parts (phil's hobby shop seem to have the needed parts in stock and serves Intl customers at reasonable shipment costs..). thanks for help, artto
The bore is only .3mm (.012'') larger & the FG engine is most likely lower compression for use W/the lower octane of gasoline so there would probably be little if any power boost.
ORIGINAL: AeroFinn
How about doing it and converting to gasoline? I am going to convert my 120 and 180 to spark with glow fuel because of possible cooling issues with gasoline, so with those problems addressed with the head for the FG you should be good to go?
ORIGINAL: spaceworm
Besides, he's looking for more power & 1 more cc is probably not going to make up for the power loss from the lower octane/lower CR.
He could, of course, convert to spark W/glow fuel & get more power W/better fuel economy than glow ignition.
My Feedback: (12)
HELP. My 100 is acting up. It's turning off when iddling for more than 1-2 mins. It was too rich so I leaned it a bit. Now it lost all compression.
The prop turns like a bike wheel. Valves?
ORIGINAL: lopflyers
It didn't kick the prop loose did it?
Is the prop nut still tight?
My Feedback: (12)
Noon, it didn't loose the prop. I was trying to work with the iddle, adjusted the HS needle a couple of times. Then the glow plug ignitor was comming out too much so I changed the plug. The tank was full so a lot of fuel came out.[:@].
Right after I changed the plug I used the electric starter and it started for a few seconds and now has no compression. The plug is still there and tight.
It is inverted but angled 15 degrees so it was a project to change the plug w/o taking the cowling off.
Now as I write this I'm wondering if the plug is not tight enough?
I would recommend checking the plug first to ensure the gasket did not fall off during installation. If it is intact and tight then there are only a few things that can compromise compression.
First are stuck valves. You would hear hissing at the carb or exhaust on compression stroke if that were the case. You may want to pop off the valve covers to check for anything unusual and valve cycling when the prop is turned.
If you got a slug of raw fuel into the chamber and hit it with the starter you could have caused some damage. Unfortunately a tear down is the only way to tell for sure if the previous checks don't point to anything specific.
I tuned my Saito 82b on the bench this week. It had been making a noise that I couldn't place. It was also leaving a very smokey trail which was cured when I leaned in the LSN about 1/2 turn.
Regarding the noise, I suspected valves. But they were spot on. Just the hint of a gap at TDC. Everything turns freely and no grinding noise when I turn the prop over by hand.
When I took the backplate off to check, I noticed that the rear/main bearing was sealed. Is this right? I don't recall ever seeing a sealed bearing in any engine. If that noise doesn't go away I'll pull the valve train and check the camshaft and cam but I don't think the problem is there.
Does anyone know if the rear bearing on the 82 is supposed to be sealed?
Bob
Bob
