Welcome to Club SAITO !
#8201
RE: Welcome to Club SAITO !
question on using a pump on a FA-82a. When flying 3D with a Fliton Inspire 60 it is recommended to fly with the tank at CG. I am a little apprehensive about flying with muffler pressure only. Any recommendations on this and the type of pump to use? I read this article http://saito-engines.info/body_pumps.html and it does mention the Perry VP-20, but only when used behind the firewall.
thanks, volkert
thanks, volkert
#8202
CA
Cline or Iron Bay regulator would be your best bet.
ORIGINAL: wagen017
thanks, volkert
thanks, volkert
#8203
ORIGINAL: w8ye
They last better with a fuel with a little castor oil. Cool Power is all synthetic oil.
#8205
My Feedback: (16)
You've been told a few times that it's a 3mm. I doubt you will get much more response?
Here's where you buy them
http://www2.towerhobbies.com/cgi-bin...?&I=LXRVA3&P=7
#8206
My Feedback: (16)
I'd like to get something straightened out here . . . .
Cool Power fuel does have low high and multi viscosity variations.
The Omega four stroke is the one with the 50/50 blend of synthetic-castor. Good luck finding a good price on it though.
Here is the link for the Omega fuel. Go down to the bottom to see the four stroke blends
http://www.morganfuel.com/omega_blends.htm
Here is a link to the Cool Power blends
http://www.morganfuel.com/cp_blends.htm
I just use regular Omega 10-15% and get along well. Four stroke Omega is probably better but I've never seen any at the hobby shops I go to.
#8209
CA
The only Omega fuel that is 50/50 Syn/Castor is their "specialty" 4-stroke. Most others are 70%/30% syn/castor. Just thought I'd clarify that, since most shops I've ever seen simply stock the standard aeroblend. Other specialty blends are a different ratio...
ORIGINAL: w8ye
Cool Power fuel does not have any castor oil in it whether it is regular, four stroke, or Heli. They do have low high and multi viscosity variations.
#8214
NJ
ORIGINAL: swixtt
Here is mine... this has NO castor in it?
#8216
TX
I have a new Saito 220 and I'm interested in finding a good 3D airframe for this engine. Who has experience with this engine and what airplane would be a good match? I was disapointed to find that slimline does not make a pitts muffler for the 220 and does not have any intention of producing one. What the H@)) are they thinking? So has anyone found a suitable muffler as well?
#8218
NJ
ORIGINAL: w8ye
Their web site is misleading?
#8219
ORIGINAL: nitrobeast
Yes i told them that. It seems to me like they put it under omega and not cool power? Have you ever seen 4cycle sticker on omega?
ORIGINAL: w8ye
i feel a little better about the fuel i have been using now. you guys had me a little worried!
#8221
Hi all [sm=spinnyeyes.gif]...I got me a new 4cycle FA- 125a. It’s a little over kill for my twist 60. I’m looking for a velocity stack to keep the fuel in and a place put an air filter. To keep the dirt and grass out of the motor However just an air filter would make me happy
#8222
My Feedback: (16)
http://www.horizonhobby.com/Products...odID=SAI50GK93
You will need a O-ring from the hardware store to seal between the intake stack and the carburetor
Use a Bruline filter.
http://www2.towerhobbies.com/cgi-bin...?&I=LX9158&P=7
#8224
Item coming soon. Due Early September, 2007[&o] is there a opt for just an air filter without the Intake Velocity Stack . I have heard the ice-ing of the carb can happen with an Intake Velocity Stack lol the air filter body will work as an Intake Velocity Stack as it is.
#8225
My Feedback: (8)
MA
i put a velocity stack on my 1.00. i tried several auto parts stores, looking for viton o rings in metric sizes. advanced auto parts had them. 8mm i.d., 12mm o.d., 2mm thick. it fits snug between the two pcs. make sure it stays centered as you squeeze it into place. lube w/a little oil (dextron for engine ARO). what 3D prop is going to fit on that a/c w/that engine? i have a .40 twist, os 46ax 12x4 (doesn't hover), would like to go w/a .72 saito, 14x4 is too big for the landing gear.
jon
jon
