Welcome to Club SAITO !
Old 06-23-2018, 05:38 AM
  #36901
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Correct, the pistons are perfect as are the rocker tips. I can't wait to run it.
Old 06-23-2018, 06:14 AM
  #36902
acdii
I switched completely to Life packs for everything after losing my Rascal to a bad NiMh pack. Damn pack tested good, held a good charge/discharge cycle, yet one cell failed after 10 minutes. I have only had one Life give me grief, but that was my fault for not taking proper care of it and letting it sit with low voltage over the winter in the trailer. Now I make sure they have a storage charge before closing the trailer for winter.
Old 06-23-2018, 06:59 AM
  #36903
Jesse Open
Jesse Open's Avatar
I never put NiMh cells on receivers I do use NiCd extensively. NiMh are okay in transmitters where the load is more constant. NiMh would also work fine on the spark maker.
Old 06-23-2018, 07:02 AM
  #36904
acdii
Thats what failed on the Rascal. I have Life for the RX and a 5 cell for the Ignition. One cell went bad and dropped the entire pack to under 4.02 volts when under load. From now on, Life with a regulator for the ignitions.
Old 06-23-2018, 07:42 AM
  #36905
Charley
Originally Posted by Hobbsy
Now, we or I was talking about two of my CH Ignition units having the 6v and the 7.4v options checked on the back indicating a range of 6 to 7.4 volts. However on 6 volts the spark is very weak and inaudible, on 7.4 volts it really cracks. I made a mistake buying the Lipo "Suck" battery, it has about 3 pages of warnings about charging it. Taking it out of the plane would be a hassle I don't need. You need to stay away from it for the first 30 minutes of charging, You can't lay it on wood while charging, that's only part of the warnings.
I have a rather weak spark in my NGH/RCE ignition. I'm using a 2-cell LiFe battery that I made up of A123 cells from a DeWalt 36V power pack - nominal 6.6V, 2.3AH. The ignition module is marked 4.6V - 8.4V but I don't know how much over-voltage protection it has. So I'm thinking of making up a 3-cell LiFe pack and using a regulator to get it down to 8.4V. I'd use NiMH cells but they'll charge up to 1.35V times 7 = 9.45V before the surface charge is bled off and I worry that it'll blow up the ignition module when I first turn it on. It's my understanding that many giant scale modelers use 3s2p LiFe batteries with regulators to power their models. Now if I can just find that regulator......
BTW, since I fly electric as well as nitro & gas, I have lots of LiPo batteries. Those safety sheets always illustrate worst-case conditions ( I never heard of staying away from a charging LiPO). Not that their advice should be ignored, better safe than sorry; but being safe with LiPos is no more of a big deal than being safe with gas or glow fuel.
CR
Old 06-23-2018, 08:27 AM
  #36906
Jesse Open
Jesse Open's Avatar
Any battery type can and will fail
LiFe and Lipo as well We had a new plane go in when a shorted regulator on Lipo took it out
NiMh are okay with constant loads within their rating but do poorly with sudden current surge demands
This is why I prefer NiCd for receiver/servo duty and generally only use them in transmitters.
I do try to avoid adding regulators and added wiring
Parts that arent there cant let you down
Old 06-23-2018, 10:47 AM
  #36907
BarracudaHockey
BarracudaHockey's Avatar
Working on a review using the FG-14 gas 4 stroke, pretty cool little motor
Old 06-23-2018, 10:53 AM
  #36908
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
FG 11 on an LT 40, I concur, great engine.
Old 06-23-2018, 01:03 PM
  #36909
Jesse Open
Jesse Open's Avatar
I traded a brand new FG 14 for used FA 100 about a year ago
Old 06-23-2018, 01:18 PM
  #36910
acdii
Shoot I would have gone for that myself. Really like the FG series. On my 11 I run the RX and ign on the same Life pack. Going on 3 years without an issue.
Old 06-23-2018, 02:58 PM
  #36911
the Wasp
Gary I thought the guy had burned some of the green Panther Piss in it, both combustion chamber roofs are tinted green, .
oh the ol Cool Power stain, had that on my first engine
Jim
Old 06-23-2018, 05:00 PM
  #36912
Rudolph Hart
Rudolph Hart's Avatar
Years ago people called cool power cruel power,never used it so don't know why it got that name.
The smaller fg gas engines don't excite me no matter how good they are.The fg carby won't allow you to put the engine back up against the firewall which you need to do on most arf's if you don't want to carry a lot of lead in the tail.None of my fa powered models need it.
Old 06-23-2018, 05:22 PM
  #36913
Jesse Open
Jesse Open's Avatar
Plus 1
Too much stuff to stuff into a plane
Old 06-23-2018, 09:00 PM
  #36914
the Wasp
yeeaa I don't like all the X-tra wires for gassers. where you gon-a put them
Jim
Old 06-24-2018, 03:29 AM
  #36915
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
I got em all in there in the LT 40 and they're neat too. I am controlling it with the tiny AR 400 Spektrum and the latest DX7.
Somehow my Boca Bearing order got hung up in some no name town in Va., the order got to Richmond at 2:20 AM this day. The USPS makes Amazon runs through here on Sunday, I don't know if that helps me or not. I'll probably get them tomorrow.
Old 06-24-2018, 12:37 PM
  #36916
Jesse Open
Jesse Open's Avatar
Never quite appreciated a nice, clean engine sprouting the snake pit
Old 06-24-2018, 06:50 PM
  #36917
blw
blw's Avatar
[QUOTE=Rudolph Hart;12442244]
Originally Posted by the Wasp
Barry if they call me judy (garland) does that mean i get to kiss goodbye to kansas? but seriously.My mad comics black sense of humour has sometimes upset people from day dot and no offense is intended.If i post too many motorcycle things say so.
I lived in Kansas for a year and a half Pete, or Rudy, or well, Old Fart. I hated every day there. The wind blew steady almost every day. I would guess that model airplane flying was a once a weekend per month kind of thing. I heard they turned all the roads there to one way streets....all leading out of Kansas.
Just watched the Top Fuel final drags this evening. A Suzuki almost took the Harley, but he was late out of the box.
I flew Lipo's for several years teaching college students how to fly indoor electrics. We used the old basketball coliseum, which was huge. I had 2 chargers always plugged in charging 4 batteries each. I think we had 2 swollen or hot batteries in all that time. But, these were mostly the small types. Still, I don't trust them. I wish I had a way to tack weld the pig tails so I could make my own battery packs.
Old 06-25-2018, 12:23 AM
  #36918
Rudolph Hart
Good to see you made it out of kansas maybe they could use the place to store all the old lipo's. I sometimes watch top fuel drag racing and there don't seem to be many harley bits in the 'harleys' whereas it's common on the jap fours.The road manners over here get worse year by year but it's the cyclists that pee me off most so i'll post a pic of my retirement scooter i'll be building and riding once i get too old for the ducati.
ps gary not sure what you mean in your post.
pps dave WHAT paint are you using to do the barrels on your saito fa90 twin? and would you like to see how they take a stocker harley worth about 20 grand over your way and turn it in to an art nouveau US 1.9 million bike.Don't hang the pic on the workshop wall your harley will turn green..oh wait
Old 06-25-2018, 01:33 AM
  #36919
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Some of KMOT's work, I keep some of his pictures to admire and and get ideas.
Clean up, the stuff is nearly a Miracle Worker.
Paint, I finally developed the touch in spraying thin coats spaced about 10 minutes apart. It seems to be durable.
This engine almost didn't need cleaned.
Old 06-25-2018, 05:33 AM
  #36920
Charley
How many cells in the LiFe pack?
CR
Old 06-25-2018, 06:03 AM
  #36921
Jesse Open
Jesse Open's Avatar
In our area we have had two major home fires caused by LiPo batteries These are apart from fires at local flying club fields
Fortunatley no loss of life yet but major home damage and total loss of vehicles
Old 06-25-2018, 06:11 AM
  #36922
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Charlie, the 1600 I have is two cells and 7.4 volts. I have since found that SR Batteries and No BS Batteries have 6 cell NIMH batteries. I have used both before and they are reliable.
Old 06-25-2018, 06:28 AM
  #36923
acdii
These are what I use
Glacier 2100mAh 2S 6.6V LiFe Receiver Battery
I put Enloops in my JR 12X radio, uses a standard NiMh setting, and is working out very well.
This is what I use in the LT-40 for the FG-11 and RX, note the two output leads.
https://www.towerhobbies.com/cgi-bin...?&I=LXYAT1&P=7
Old 06-25-2018, 07:01 AM
  #36924
Hobbsy
My Feedback: (102)
Hobbsy's Avatar
Whoa, my 90-T grew horns, er I mean Velocity Stacks, I do stuff like that simply because I can.
Old 06-25-2018, 07:47 AM
  #36925
BarracudaHockey
CR
LiFe packs are 2s unless you get a turbine ECU battery in which case its 3S. You can use them like a 5 cell NiMH, except they charge faster, discharge faster, and stay charged forever without damage while sitting
